- Nov 4, 2013
- Atlanta, GA
Hello all, having some odd system issues.
I have a MSI Z87-GD65 Mobo with an i5-4670K. I had the system stable at 1.265 vCore and a multi of 47. The only other changed option was RAM voltage and an XMP setting. When playing BF4 I have began experience hard locks without a BSOD. When I restart the system the display is disfunctional.
What has worked is removing the GPU (GTX 670 2GB) and connecting to the onboard HDMI. System will then boot and I can reconnect to the HDMI on the 670 and the system seems fine from that point. Very odd issue.
I am thinking its the PSU not giving correct voltage. I have reinstalled Windows and still get the same issue. I have upped the vCore up to around 1.295 and will attempt again tonight.
What I don't understand is I can run AIDA 64 for 24 hours on 1.265 (SAME SETTINGS) and am rock solid stable.
I'm just trying to eliminate the cause and I'm thinking it could be the PSU, however in my experience the system wouldn't resume functioning as normal because of a bad PSU. Is it possible that my PSU is working but under BF4's load its not sending voltage properly but will come back on after my troubleshooting steps?
I've bought a new mobo to elimiate that as a possibility and its still occuring. GPU works fine and stress tested it to make sure. I'm just a little lost as to the actual cause. Obviously removing the OC would be a good step, but then why would it be stable for 24 hours under synthetic testing?
Any input would be greatly appreciated, thinking of trying a new and higher watted PSU. Suggestions?
