- Aug 1, 2010
I am thinking about getting the Ryzen 1800x cpu and ASRock Fatal1ty X370 motherboard but ram not sure exactly what size I need but would like to match the board color and maybe led. For the video card not sure if I should wait for Vega/Upgrade to a new card or keep the one I have and get a decent card for the other computer for backup/guest computer? Monitor I would say I am due for an upgrade after 9 years for one and 7 years for another. I am using for my primary monitor is an Hp w2408h and secondary monitors are Asus VE246H and Samsung T24C550ND I think this is the monitor which is a guest/extra tv. I would like to upgrade my case to hold more hard drives easier then I can now, also would like to have Usb C for the front panel, and would like to do liquid cooling and would need to hold 2 rads either both 360 or one 240/280 and a 360 with reservoir and pump. If there is no case that fits as many hard drives as the motherboard could handle then I can change the motherboard and case requirement. This upgrade is for using 3d modeling programs and gaming along with streaming most likely.
