First off, if someone feels this is in the wrong category/sub-category, please move the thread and accept my apologies. Because I am leading towards this issue being caused by the motherboard, that's why I posted it here.
I have had my custom built PC for over 2 years now. Everything has been great until recently. My system one day just cut off out of the blue; I'm on a UPS so I knew power wasn't the problem. I tried to turn it back on and it came on and posted as normal but after about 10 seconds of power, it turns off again. Because I am surprised by the symptoms, I don't do anything and just try to think of what happened; during this thought process, the PC turns itself back on and then back off again. I noticed that it would continue to turn itself on and off repeatedly and apparently indefinitely.
If the power supply switch is turned off and then turned back on, the system will not turn itself back on again unless the power button is depressed. I noticed that if I press the power button, the PC comes on, and then I press the power button again and leave it depressed, the system stays on until the power button is again released. I have been running my PC for a couple months now with the power button taped down so that the PC turns on. The PC runs great and has no limitations at all with the power button taped down.
As far as troubleshooting, I confirmed it is not the case power button that is the issue as I removed the motherboard from the case and used the power button built onto my board. By removing the motherboard from the case, this also confirms that a short is not the cause.
My only two conclusions; the motherboard is bad or the PSU. I am more inclined to think it is the motherboard because if the PSU was not putting out it's rated capacity, the PC would have other signs of problems especially when playing games or other resource intensive tasks that would draw more power from the PSU.
Please advise. Any input will be appreciated. Thanks in advance!
PS: If you feel the specifics of my hardware are necessary to help form your opinion, I'll be glad to post. Keep in mind, the system has been fine for 2 years and has always been behind a UPS.
