Radiator fittings are at the top. Planned pump placement was on the lower left of the mid-tray area. MCP355 with XSPC top, so it's a top inlet, side outlet.
Equipment:
MCP355 w/XSPC top -top inlet, side outlet
MCR320QP - front mount, fittings at top
MCW82 on GPU
D-Tek Fuzion v2 on CPU
I have one t-fitting, one y-fitting, and a few quick disconnects on hand.
I'm thinking:
Pump outlet => Rad => t-line => CPU => GPU => pump inlet
Probably difficult to prime and bleed since the water flows down from the top.
OR
Rad => t-line => Pump => GPU => CPU => Rad
Mount the t-line in the from the rad to the pump. Easier to prime, more awkward routing-wise, and the GPU comes before the CPU which isn't ideal. But likely easier to bleed since the fluid would flow from bottom to top.
OR put pump up in the 5 1/4 drive bay area (there's not much room for tubing bends though, only one way this fits)
Rad => Pump => CPU => GPU => t-line=> Rad
Cleans up the tubing, but again make it tough to bleed.
I'm not sure any of these are "good" options.
I'm trying to get away without buying more gear, but if I have to, c'est la vie I suppose. Am I just better off with a reservoir? What's good in the world of reservoirs these days? I've heard that the acetyl ones tend to crack. The Aqua Aqualis borosilicate tubes are nice, but only mount on their pumps. The easiest option if I went for a res would probably be one of the pump top versions. Are they all the same, or are some better in quality/performance than others?
I'm horribly low on information in this regard as my system always had a giant external reservoir in the form of my Reserator. Now that it's been declared unusable, I've got a system in pieces that needs a solution. There are tons of options, but I have no way to really differentiate between them.
