- Oct 6, 2009
I know this is a old chip in todays game. And I also know that in comparison this is a slow machine.. but its what i have and and just never knew this chip had this potential.
Basically.. the gate way doesnt come with that stock cpu fan and cooler.. its has a heatsink placed right on top
Gateway Foxconn Skt 775 P4 Passive Heatsink
then its has a fan on the front of the case with a tubluar piping running down to the hatsink.. im taking it this is gateways own way of keeping things cool..
well my questions is can this be overclocked any based on this colling setup and this motherboard?
heres the stats on the mb
Form Factor Micro BTX
Dimensions: 10.5 × 10.4 inches
CPU Support Package: LGA775
System Bus Support: 800/533 MHz
Memory Support Two DDR2 DIMM slots
1.8 V (only) DDR2 SDRAM Dual Inline Memory Modules (DIMMs) with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs
Note: Single sided ×16 modules are supported but double-sided ×16 modules are not.
Non-ECC DIMMs
Serial Presence Detect
DDR2 533 or DDR2 400 MHz SDRAM DIMMs
Maximum total system memory: 2 GB
Minimum total system memory: 128 MB
MCH (Northbridge) ATI RC410 Rev. A12
ICH (Southbridge) ATI SB450 Rev. A13
Firmware Hub 4 MB LPC Flash ROM
Integrated LAN Integrated 10/100 LAN Realtek RT8100C co-layout GiGi RTL8110S
Integrated Audio Interface: Azalia 8.1 channels
Model: Realtek ALC861
IEEE 1394a Controller VIA VT6307
Serial Input/Output (SIO) Winbond 83627 EHF
Add-in Card Slots One PCI Express ×16 (graphics interface)
One PCI Express ×1
Two PCI conventional
Rear panel I/O Ports Four USB 2.0 ports
Two PS/2 (keyboard/mouse) ports
One parallel port
One VGA monitor port
One RJ-45 LAN port
Six Analog audio jacks
Internal Headers Two 2-port USB 2.0 headers (2 × 5)
Front panel audio header (2 × 5, mic / headphone)
Front panel header (2 × 5)
IEEE 1394a front panel header
Chassis power LED header (1 × 3)
Floppy disk drive connector
Primary IDE connector
Secondary IDE connector
Four Serial ATA connectors
Two ATAPI headers
Clear CMOS jumper
Main Power Connector 24-pin (2 × 12)
Auxiliary 12V CPU power connector 4-pin (2 × 2)
CPU Fan connector
Rear fan connector
I know this is a funky MB as i wanted to move it to my liam case but it seems these were built for gateway cases only and are actually on the opossite side from a normal case.
I do have a very good 500watts powers supply i can add to this setup if the MB takes it. I was thinking of purchasing one of these
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
if my current setup cant keep it cool
I just dont know if based on the stats on this cpu if it is even worth the time..
and if not.. is it worth it to find a refubished MB and slap this chip in? Are there any MB that i can grow with and leave this setup behind when I have the money?
any help is great.. i just really need more power but working with limited sources.
its a gateway GT4024
Non-ECC DIMMs
One PCI Express ×1
One parallel port
One RJ-45 LAN port
Two ATAPI headers
Clear CMOS jumper
CPU Fan connector
Rear fan connector
