Yeah, that'd be about right. My current setup is pump -> radiator -> CPU -> res / bleed tank -> pump. It doesn't make that much of a difference where you place the individual components, because as there is only a .1C difference in waterblock intake - outlet temps generally speaking, it's easiest to route the components where they fit most easily in your case, and have the shortest hose path.
