- Oct 13, 2010
Looks good Funsoul, are you going to post the Vantage run if Not I will do one.
Just my POS 4690K that only clocks to 4.4GHz with 1.29v @80°C under load, though I've not pushed it that hard since it was in my main PC. Probably can't beat Console's 4670K at 4.89GHz though.Hiya TT!
Do you have another chip for that socket? I've got a pretty strong 4790k that should get us a much higher score to sub.
Tech Tweaker, Thank for helping out with the competition.
Thank you for jumping in TT!! Don't recall sb volts but if you manage to get that dead board of mine to actually post, am pretty sure there are a lot of profiles there :/ That said...maybe search hwbot for what volts peeps run/ran under water for whichever bench.
SC2: GPU 3D http://oc-esports.io/#!/round/team_cup_2017_sc2
Stage 1 - Aquamark3 GeForce 8 (3 GPUs) --- ||Console|| / 8500 GT / 60533----jiccman1965/GTX 8800/351705 ----funsoul/8800gt 512/419852
Card's only on air and something's really, really wrong with my cpu (score)...what the heck?? Could 4c/4t vs. 4c/8t explain the difference (don't think 7x64 vs XP64 would do it?)? I know aq3 only uses 4c but still :/ BTW- TT...I apologize! My card's an 8800gt not gts. Iirc...you have a gts? If so...that'd be great to run if you felt the urge!
Hopefully will figure out the cpu issue and have time to take it and the card cold and give it another run. That said...am thinking we might be better off if I try to fill in some vga gaps using the 7700k. These are the ones that look useful for us atm:
- 780Ti/FSE (TT already covered this card but I should be able to improve with the extra cpu muscle. I'll focus on the other cards first)
- HD4850/3dm6
- gtx980/3dmv (only 4c/8t )
- gtx285/3dm1
Thinking the gtx980 first as it'd complete that stage for us? Then gtx285 followed by the hd4850?
I will also do this bench, Stage 2 - 3DMark03 AM2 HD3000 (1)
Thanks TT
Yeah...thought about it some more....thinking that using 4c/8t then setting aq3 to use all 8 'cores' led to the lower than expected cpu score. Will definitely try it again and try to bring it up to where it should be.
Since we're getting close...want to check and see where we're at and who, if anyone, can fill in the gaps.
SC1: CPU 2D http://oc-esports.io/#!/round/team_cup_2017_sc1
Stage 2 - SuperPI 32M 5GHz LGA1155 (3 CPUs) ----jiccman1965/3770K/06m.36.959---Johan45/3570k/ 6m 29.328s---Tech Tweaker/Core i5 2500K/7min 29sec 733ms
Finished! Good job guys!! Icing on the cake would be if anyone can improve on any of our existing subs.
Stage 3 - HWBOT Prime LGA1150 (3 CPUs) --- jiccman1965/4770K/6805.79---Tech Tweaker/Core i7 4790K/6059.26 pps
I hope/plan to run my 'new to me' 4790k for this one (sorry TT). If all goes well, should be able to run this at 6.3GHz-ish. We need 1 more cpu for this stage. Anyone? Beuhler, beuhler?-Yeah, I'd been planning on submitting for LGA1150 for a while, just to get us a third sub to move our ranking up, know being limited to AIO cooling limits my score though.
Stage 6 - Cinebench R15 S939 (3 CPUs)--- ||Console|| / X2 4400+/ 88CB,
I've got a working 939 setup (thanks Mr.Scott!), will try to get at least 1 sub in with a cpu under ss. Anyone have 1 more chip they could run?-I have many 939 chips I could run, problem is finding the time, and whether or not my DFI SLI-DR Expert still works (haven't tested it in probably a year or more). Athlon 64 X2 4800+, Athlon 64 X2 4200+ Toledo (or Manchester, which doesn't overclock as well), Opteron 165 (if Opteron's are allowed) (also have an X2 4400+, but that won't help since we already have one up).
Stage 1 - Aquamark3 GeForce 8 (3 GPUs) --- ||Console|| / 8500 GT / 60533----jiccman1965/GTX 8800/351705----funsoul/8800gt 512/419852
Done but if we could get another 300K+ sub, it'd help us a lot in this one. I'm hoping to re-run this one to get my score up where it should be.- I have an 8600 GT I could run, it won't get us a 300K sub, but it might hit 200K.
Stage 3 - Fire Strike Extreme GTX 700 (3 GPUs)--- Tech Tweaker / 780 Ti / 5737 ----Johan45/GTX770/ 4066---jiccman1965/GTX 780/5307
Time allowing, I could try with my 7700k/780Ti (sorry again TT ). With all the other gaps, though...may not have time to get to this one. :/ - Eh, it's alright. I just submitted in case no one else had a card with the same GPU revision.
Stage 5 - 3DMark06 HD 4000 (3 GPUs) --- Tech Tweaker / HD 4870 / 19,004
I'll dig through cards and look for my 4850 (and any other hd4xxx cards). -I have a higher sub saved if we need it.
Stage 6 - 3DMark Vantage GTX 900 (3 GPUs) ---Johan45/ 5960x/ 980Ti/ 75250
We need 2 more cards for this stage. I'll try to get my gtx980 set up properly and try for a decent sub (although having only 4c/8t will limit this). Who's got 1 more card? I've also got a gtx960 that I could run if someone else has a gtx980. -Afraid I have nothing else for this at the moment, only had my 980 Ti.
SC3: MISC 1 http://oc-esports.io/#!/round/team_cup_2017_sc3
Stage 1 - WPrime 1024M S478 (2 CPUs)
All my s478 is gone so nothing I can help with on this one Who's got old school?? -I have a socket 478 HP sitting up in the attic, it can't overclock but it would be a score.
Stage 2 - 3DMark01 GTX 200 (3 GPUs) jiccman1965/GTX 280/93566
Will try this with the 7700k and a modded gtx285. Won't have time to take the card cold but an air sub with the cold cpu will be better than nothing. Someone have one more card so we can complete this stage? -I have a GTX 260 in my LGA1155 rig right now, need to test the card to see what it's capable of overclocking to (and what it can even score at stock settings).
Stage 3 - PiFast LGA775 (3 CPUs)
Don't have a strong cpu for this one but will try to get something done even if the cpu's weak and only under ss, it'll be better than nothing. Who else can help here? David/kicsi? I know you're a pretty wicked 775 guy. -I have E8500 (4.4GHz I think), E8400 E0 (4.4GHz), E7500 (4.2GHz), and a Pentium E6700 (4.3GHz) (and those are probably the strongest CPU's I have). Do you need your REX back, or do you have another working board you can run 775 on?
Stage 4 - Memory Frequency (4 MEMs)---- ||Console|| / DDR/268.9---- jiccman1965/DDR3/1377.9---funsoul/ddr4/2303.4
Need a ddr2 sub. Anyone? I could do ddr2 (which would likely not be so great) but think David/kicsi will get one done for us? -I could hit DDR2 if I get around to loading up my LGA775 system (674MHz was my max in 2015). I'm also capable of putting in a higher DDR sub (if my 939 board still works), if someone else can get a high DDR2 sub.
SC4: MISC 2 http://oc-esports.io/#!/round/team_cup_2017_sc4
Another one where I've got nothing. Just need 1 for this team....who's got it? -I have AM2 hardware, but no HD3000 graphics cards at the moment.
Stage 3 - Cinebench R11.5 Sandy Bridge Mobile (3 CPUs)
Another I've got nothing, please check your laptops. -All I've got are AMD laptops and one very old PGA478 laptop.
Stage 4 - Fire Strike Sandy Bridge-E GTX 400 (1) ---jiccman1965/GTX 480/4229 Nice jicc!!!! -I have a GTX 470 that just arrived, and a semi-working LGA2011 Sabertooth X79 (has bent pins I mostly corrected in the socket, some are broken off though, so one of the RAM channels glitches out sometimes). Unfortunately don't have an i7 CPU for it yet though, just some Xeons.
Stage 5 - 3DMark Vantage LGA1155 HD6000 (2 GPUs)----jiccman1965/HD 6970/27626
Just need 1 more sub to complete this one! Who's got this? TT? You have something for this stage? -I have an HD6870 on the way, assuming it works I can do something for this stage.
Stage 6 - Geekbench3 LGA1150 (3 CPUs) ---jiccman1965/4770K/21455---||Console||/Core i5 4670K/14889 --- Tech Tweaker/Core i7 4790K/17792
Hoping/planning to hit this with the new 4790k at around 6.2-3GHz (apologies again to TT for my lack of coordination with him ) We need 1 more cpu....who's got one? -We already have three, so not sure why we'd need another one if you can best my 4790K score (if you can get sub-zero, you probably will easily), unless there is an issue with one of our other subs.
About a month to go. If people could dig through their hardware and update this thread with the goals/hopes/plans/dreams, we can try for a good push to the finish! GOOOOOOOOO team!!!!
