- Jul 21, 2012
So i finally decided to upgrade my Amd Phenom II Black Edition X6 1090T from stock cooler to Corsair H80 water-cooling, which arrived earlier today. When using stock i hadn't oc'd my CPU at all but both my CPU and mobo (Asrock 890FX Deluxe4) supported Turbocore technology which made the 3.2ghz stock sometimes made half the cores go up to as high as 3.8ghz if lucky although usually hovering around 3.6ghz average. I never really monitored my CPU temps because i assumed i wouldn't need to unless i OC'd it, but i found out that my CPU temps were going between 60-70 C under high load.
Anyway i installed the H80 earlier today & did a lot of tests with prime95, it improved cooling massively without tweaking anything it went from 70-72c in prime95 torture test to 48c maximum. Now for some reason when turbocore is enabled i cant see the CPU CORE temperatures. Anyway, since my cooling was decent i Disabled turbocore & overclocked my CPU to 3.85ghz and ran a torture test for 1 hr with no problems, its still working as i type this so all is well. But after doing more prime95 tests and using multiple monitoring apps im not sure the temperatures are correct?
The highest my CPU went with the new OC in prime95 torture was 60c, and yet the cores were only 35c , the cores usually around 20-23c as idle, and CPU temp 32-35 idle, are the cores really suppose to be that much lower than cpu temp. I heard that there is problems with some mobos not accurately reading x6 CPU's? also Speedfan and OC tuner had a whole 8c cpu temp difference at one point with both programs running idle, which is weird to say the least. I've been using monitoring programs such as ASRock OC Tuner, Speedfan,CPUID HWMonitorPro, CPU-Z, AMD overdrive and others just to make sure.
All of them show that CPU temps are definitely a hell of a lot higher than my Core temps both idle and under load. Is this normal?
Also If i were to overclock even more whats the max temp i should stop at ?
