proth said:The reason why I like this forum better than XS is people are kinder, friendler and more helpful, less "clicks" to contend with and a lot less egos and self proclaimed experts. Mosts posts here are thought out and have purpose, either to inform or get help on something, rather than XS which is more like a global chatroom for computer geeks of all ages, requiring mods to constantly step in and stomp flames out. Keep in mind everyone's a novice at some point and it's in everyones best interest to share knowledge politely and treat people with respect. As for me, I'm 49, an expert at somethings, noob at other things, but always welcome new people, try to help out when possible, and very grateful of others that have helped me.
By the way
EDIT: Ok here's some noobish questions:
I'm thinking about buying a water chiller that can pull down to -40. Can my Alphacool 1510 handle this cold.?
How about the Danger Den x1900 water block.?. Got a feeling the acrylic cover may be a problem...
thanks
Gautam said:Alright, I'm not sure of precisely what sorts of questions you're looking for in this thread, but I'll try to bite.
The time has come for me to rework my converted A/C chiller. I'd like to hear your thoughts on HX'es. Plate HX'es look perfect to me, compact and very high surface area, but very expensive as well. There are some other designs I've heard of too...tube-in-tube, two tubes sort of wrapped around each other with opposing motion, etc. Then there's the old standby of simply keeping the A/C's evap. Discuss?
NoL said:Exactly, but also never pump into a palte hx, wayyyy to much restriction.
NoL said:Yes, with my mag3 I was losing alot of head/flow by pumping thru, temps were even bad, reversed the pump and woohoo!
NoL said:Variable sized HX, you'd need a coaxial with multiple outputs that you could solenoid. To open up whichever suction hole you want. Or just get a pressure control on the suction.
jinu117 said:Anyways, here is what I've been pondering...
Some kind of variable sized HX... where HX ratio can be controlled... without being wasteful... basically this is one MAJOR problem with mixing gas in SS for very cold temperature. To play safe and nicely, you need to have certain amount of HX happening in SLHX and making it precise on load for each situation isn't easy. If there is a way to make heatexchange variable, I can easily make -55c 200w loaded single stage units that is safe to use ... let's start thinking
thanks
