unclewally88
- Mar 26, 2019
Hey all, been lurking along time. Built a couple overclocked machines in the past with guidance I have read from here.
Need some advice. Looking at doing a small form factor build.
Core I5-9600K
Asus Rog Strix Z390-I Gaming Mini ITX board
Kingston - HyperX Predator 2x16GB DDR4-3600
Gigabyte - GeForce RTX 2060 6 GB Mini ITX OC Video Card
Fractal Design - Core 500 Mini ITX
EVGA - SuperNOVA G3 650W 80+ Gold
Fractal Designs - Celcius S24 87.6 CFM Liquid CPU Cooler
Will it all fit? It sounds like I could fit a full size GPU in there, so I'm not sold on the Mini ITX one. Mostly I want to be assured that the FD H2O for the CPU will work with this combo in the top of the case.
The other issue I have had in the past is that I have run an older build through my AV system - Yamaha RX-A3030 reciever to bose surround sound and 60" samsung TV with 240 hz refresh rate. Sound output on past machines has been through a Creative Labs Audigy card taking up a PCIE slot and using the analog outputs from the card to the receiver. There isn't an extra PCIE on this MOBO. It looks to have a optical sound output that I can run in parallel with HDMI cable to reciever, then run everything to the TV via HDMI.
Will use for gaming and some streaming.
Thanks in advance!
Waldo
Core I5-9600K
Thanks in advance!
Waldo
