the next pics i will take i have to wait for the glue to dry so you can get a feel for the idea. that tube btw is the same size as the flexible tubing you saw earlyer so i will have to heat it up and stretch it over the outlet for a nice tight fit
the glue is called X2 and is in all japanese so thats all i can really tell you.
i dont have any money atm so untill i get a case / rad i cant do any more because i always build the Res to fit in the case . once i get a case/rad combo i can then make the final decision on the heigth and what angle and spacing to drill the inlets. so just need to know what case i will have for final decisions then it will all flow together ( pun intended)
currently i was thinking of a wavemaster or a lianli pc60 but i would like a specialy modded bonnaville core to make 2 parallel 1pass cuircuts. ( will require buying 2 of them just to have end cap of second one) unless i can find a more suitable core
see i want the core orientation a specific way because of how i plan on mounting the pump.
