the string is just to hold the mesh in place while the glueing is being done because it will be glued in position upside down so i can make sure the position is square using my uber secret method!
go figure.
after coming back from the store i found and bought another screen almost the same as the one you see inside the res except its copper only. im hesitant to take it apart just to replace the screen so will leave it the way it is untill i see some possible oxidization which may not occure depending on how much nickle is in the steel
the purpose of the mesh is to stop suction created vortexs .
you remember watching the water drain from your bath tub with a wide 1 inch opening into the drain. well imagine a pump sucking action that already creates cavitation.
as for doing everything by hand. pretty much but what you see will be nearly complete. i may suspend it from the top of a case using very thick military grade retainer bands ( like rubber bands but much thicker )
i could actualy seal the res directly to the pump and suspend all of it to completely elliminate vibration but i think that eventualy the vibration stress would make the seal break and cause a leak. hence the tubbing bridging gap
