1. What version of p95?
2. No, I mean test length needs to be at least 30 mins for the loop to normalize and saturate.
3.
https://www.amazon.com/Phobya-Inline-Temperature-Sensor-Matte/dp/B00EUREX1G
4. I assume you measured off the cpu in hand?
5.
https://modmymods.com/barrowch-g1-4-oled-display-flow-meter-v2-black-fbft03-v2-black.html
6. Ok...whenever you settle on a config, dont change it for testing otherwise, you are testing variables other than the block.
1. Whatever the newest version is on the Prime95 site which is V29.8 build 6.
2. Affordable, i'll order maybe a half dozen of them up later in the week. Hope I can get a quantity discount...
3. I requested this information from Intel and AMD as an interested manufacturer, and I really got a lot of weird replies. I used a laser 3D scanner on an i7700K as I didn't have a Ryzen in hand at the time. The resolution of this scanner isn't the best, so i had to generalize some things.
4. I'll check around since that isn't in stock.
5. I'm just getting the testbed put together. I need to make sure I am not testing on a subpar system, so the first step is to make sure that each component is functioning within what one considers to be a performance envelope. Data will be gathered after this without changing any other variable, and this will allow said data to be analyzed without fear of tampering. I don't have any intention of blowing smoke into any orifice and this includes my own. If I'm doing this, I need to do this right.
Let's be honest, in materials and tooling alone I am already well on my way to spending a good bit of money. There is a lot of facets to this thing that many wouldn't realize extraneous to the actual design of the block. As one person, I am not making the optimal decision the first shot sometimes and end up having to re-buy specific items in a different size, thread, gauge, etc. I'll be the first to admit that, but mistakes lead to data and the data allows future decisions to tend towards correctness. I think that having a block that works, performs within a reasonable envelope for not having many things revised, and mounts with a completely custom mounting solution is a great start. After the beginning of next week, I will have more available machine time and I can finally get going with ideas. I have pretty good size plates of tellurium copper 145 and brass 360 as well as some 303 stainless for a future idea.
I bought the stuff to electroplate nickel... but it's seriously hard for me to give up copper's drastically better thermal conductivity. I'd much rather just clean the block more often than to sacrifice 200+ W/m K... but the industry seems to have gone the way of electroplating, so I must be missing something. Anyone care to elaborate on this?
