Update.
Today I finally got around to playing with my Aquaero 5 LT.
Until now, i had just run the system with a max rpm of 900rpm.
To the point. I love this controller, I cant see my self ever using any other controller, unless cheaper, and just as good controllers come along on the market.
I have spent a few hours setting up the controller today, installing the sensors for data loggin, and also setting up the fans for speed control via the temps.
The fans setup is:
On one channel 120 Push/Pull as the top fans on the 240mm rad.
On one channel 120 Push/Pull as the bottom fans on the 240mm rad.
These are setup to run on the CPU package temps.
The top 2 fans will run on at 22% about 350/400rpm when CPU temps go above 40degress, and the bottom 2 fans will start running at same speeds, but not until CPU package hits 50degrees, from there on they pretty much follow the same scale, in speed increase as temps go up.
The top 360mm rad with the 3x 120, is running a similar way, they are run of the GPU #1 temp, and kick in at about 45 degrees and slowly increase in speed as temps go up.
I simply love this system! Of course there is still a bunch of tweaking with the setup, but for now Im very happy, and the system is dead silent.
As far as the full system, I am currently running the CPU at 4,4Ghz @ 1.250v, and seems to be stable, so far. GPU's are running stock clocks.
I ran a 3dMark11 test, to compare with the old 3770K setup.
I had to overclock CPU, GPU and Ram to hit around 16000 points.
Currently the ram is running at stock speeds (1866Mhz stock ratios) , along with the GPU's, and I hit 15800points, so i am very pleased with the rig so far.
http://www.3dmark.com/3dm11/7378037
That said, I am having some data reading issues on CPU wattage, and shut down issues, some times the rigs stays on, after Windows has shut down.
EDIT:
Did a small OC on the GPU's I am very happy with the results:
http://www.3dmark.com/3dm11/7378303
