What's this? Could it be?
The Holy Grail of Cooling
Found in the Digi-key catalog. (Digikey part number P11440-ND)
Listed with the low low price of $29.88 for a 60mm X 90mm sheet.
None in stock.
P11440-ND“PGS”
(Pyrolytic Graphite
Sheet) Heat Sink Sheet
Features:
• Excellent thermal conductivity: 600 to 800 W/(m.K),
twice as high as copper, three times as high as
aluminum
• Light weight: the same as water (Specific gravity: 1.0
g/cm3), 1/9 that of copper, 1/3 that of aluminum
• Flexible sheet, easy to be cut or trimmed and
withstands repeated bending
• High heat resistance: Stable up to about 400°C even
in the air
• Low thermal resistance
• The main component is carbon. Minimal impurities
and outgassing
• Excellent heat transferring performance. Heat sink and
even distribution of heat
Application Examples:
• Notebook personal computers, DVDs, DVCs, mobile
phones
• Semiconductor manufacturing equipment (Sputtering,
Dry etching, Steppers)
• Optical
Items Characteristics
Thickness 0.1±0.05mm
Density 1.0 g/cm3
Thermal Conductivity (a-b plane) 600 – 800 W/(m.K)
Thermal Resistance 0.4°C/w(10N/cm2)
Electrical Conductivity (a-b plane) 10000 S/cm
Extensional Strength 19.6 Mpa
Expansion Coefficient (a-b plane) 9.3 x 10-7 1/K
(c axis) 32 x 10-6 1/K
Heat Resistance 400°C
Bending (angle 180, R5) 10000 cycles
Dimensions – mm Digi-Key Price Panasonic
L x W Part No. Each Part No.
125 x 180 P11438-ND 94.62 EYG-S131810
125 x 90 P11439-ND 51.46 EYG-S091310
60 x 90 P11440-ND 29.88 EYG-S060910
General Characteristics of PGS
PGS (Pyrolytic Graphite Sheet) is a heat sink sheet with high
thermal conductivity and high flexibility.
PGS is made of graphite with a structure that is close to a single
crystal.
This is achieved by highly-oriented polymer film sheet, a process
which has never been implemented before.
None in stock.
P11440-ND“PGS”
(Pyrolytic Graphite
Features:
aluminum
in the air
and outgassing
phones
• Optical
Density 1.0 g/cm3
crystal.
