- Apr 10, 2001
This may be a dumb question, I've been full of those lately. I just got an AX-478 and it came with 8 screws and 4 rubber washers? Does the fan just mount directly on top of the HS or do you put the rubber washers between the fan and the heatsink? Why 8 screws?
Also, I've read the thread about poor performance due to a bad solder job. I'll keep an eye on this and see how mine does. Hopefully I won't have any problems. I ordered mine from the Heatsink Factory last Wednesday.
Thanks in advance,
Thanks in advance,
