- Nov 29, 2010
As some of you know, I was looking for a cooler to replace my hefty Copper TRUE (Thermalright Ultra 120 Extreme): I wanted something that was not only lighter but also something that could at least match the performance of the mighty TRUE. A few days ago whilst conducting my daily "thermalright" search on ebay D) I noticed that somebody was selling a used IFX-14 at a very, very good price, so I took the plunge without needing to persuade myself and endured four days of agnoizing anticipation until the cooler finally arrived.
The coolers meet before the showdown:
One thing I wanted to draw particular attention to is the base of the IFX-14, which was so curved that it could be seen very clearly without the aid of a razor blade:
Despite the state of the IFX's base, I proceeded with the comparison to see how a "vanilla" IFX-14 would compare with a lapped TRUE Cu.
Here is the procedure I observed for the comparative tests:
Speaking of results:
As you can probably understand, I was sorely disappointed in the IFX-14, both in terms of silent performance and voltage scaling performance: with the CPU at 1.4v (BIOS), the temperature reached 93°C even with the Delta at full throttle. At first I thought that the cooler might be faulty, but the other results clearly show that it can cope with a high heat load and that it scales well with increased airflow/static pressure - even to the extent that it matched the performance of the TRUE.
I also thought that the IFX-14 might benefit from having a 38mm fan on each tower rather than a single 38mm fan sandwiched between them, so I tested again with two powerful 38mm fans and the results were the same: temps rising to 90°C and beyond.
Not wanting to give in so easily, I lapped the IFX-14 and reinstalled it with a pressure mod to compensate for the copper that had been removed from the base.
Although lapping to a "mirror" finish doesn't do a great deal for temps, it certainly helps verify the flatness of the base!
And here is evidence of what appears to be very good contact with the IHS:
The result after lapping and pressure modding? Load temps were EVEN WORSE than before! Load temperatures at 4.1GHz with two Xilence fans rose to 90°C!!
I'm afraid I have no explanation for this - I fully expected lapping the IFX-14 to have a pronounced impact on its performance, but unfortunately it was not meant to be.
Despite the poor performance of the IFX-14 I really enjoyed conducting this comparative test, and I hope you enjoyed reading my findings.
- Prime 95 Blend was run for 20 mins using each cooler and each fan configuration. After 20 mins the max temperature reading for each core was taken from Real Temp and averaged out to give me a final value.
- A temperature threshold of 90°C was imposed and all tests were aborted if and when this threshold was reached or exceeded
- The Delta AFC1212E was placed between the two towers of the IFX-14; for dual fan tests, the IFX was configured as push-push whilst the TRUE Cu was configured as push-pull
- The same mounting hardware was used for both coolers (TR 1366 bolt through kit Rev. B)
- The same thermal compound was used for both coolers (Arctic MX-2)
- The ambient temperature was maintained at 19°C for all tests; there were no drafts or cold air currents which could interfere with the results
