- Feb 13, 2001
- Twin Cities
- Thread Starter
- #101
That's the best news I've heard since this thread started! Thanks for the update Anarchy.
Hoot
Hoot
Hoot (May 02, 2001 11:36 p.m.):
Hoot
Sklathill (May 03, 2001 12:00 a.m.):
Thermoengine stock - 43
Imitation GORB - 42
Sklathill
Anarchy69 (May 02, 2001 11:52 p.m.):
Glad to help Hoot. Actually it's been on [H]ard|OCP since yesterday... just no-one bothered to click the image lol
SO... since you seem to be happy about it, can you tell the viewers just what the hell it means? Under-educated formerly public school victims like me only read the last sentence. I would like a translation of the numbers
Thanks!
Anarchy69 (May 03, 2001 12:08 a.m.):
Bro, you're using the stock fan, thermoengine is supposed to shine only with a better fan. Even the sites that praised the thermoengine spoke of the crap stock fan. Suits me, I just want quiet... with the option to upgrade to a noisy bastard later, should 1.33ghz become too slow... but if you want the performance level that has been praised, you might want to stick a big noisy vornado fan on that thing.
If you compare a Thermoengine that is hollow versus a thermal engine that is solid, the following will be true: the same amount of heat energy will have less heatsink volume in which to accumulate.
Therefore, the hollow sink, given the same input energy, will be hotter at the fins than a solid one, because a solid one has more volume to "soak up the heat".
However, the only place where there is active export of heat is at the fins. The more heat that is transferred to the fins, the more effective the sink is at exporting heat.
The hollow core does not magically "pipe" heat away. Calling it a heat pipe is a serious misnomer. However, air is very poor at holding heat. A vaccuum is incapable of holding heat. The hollow chamber's main point is merely to NOT HOLD HEAT.
An ideal fansink would:
A) maximize contact area with the cpu (limited by cpu size in most modern sinks, and aided by thermal paste such as arctic silver)
B) Have as high an export area to heat holding volume ratio as possible. (fanned fin area/volume).
C) Push as much air volume across the export area as possible.
A hollow thermoengine is more ideal because of point B, and therefore, should be more efficient.
Why would Thermosonic go to all of the trouble and expense to develope a hollow core if it was not better than a solid core version?
T. Random (May 03, 2001 06:00 a.m.):
I would consider the comparison conducted by Thermosonic rather reliable. It shows a small but consistent difference in favour of the hollow core version. They measure the thermal resistance (junction to ambient) to be 0.6 C/W for the solid core and 0.56 C/W for the hollow core. In practice, that would mean 1-2 C difference in cpu temp, depending on power consumption.
-Qwegji- (May 03, 2001 11:55 a.m.):
Ok, I dont know much about what is going on but I found out last night about this. I took a look at my ThermoEngine and it has a solid core. I was told by a friend that it gets 15C hotter than a hollow core one and so he said that the solid core one is not worth the money. Im not to sure about that, but this is mine:-
I have a ABIT KT7A-RAID with a AMD T-Bird 1GHz AXIA @ 1.25GHz, also I have Juno P6 Full Tower(5 * 80mm fans). When idle the CPU is about 28C, when I start using games and programs it gets up to about 39-41C.
I dont know to much about it. So could someone tell me whether this is good or bad and is worth keeping the cooler?
Colin (May 03, 2001 09:15 a.m.):
"Rather reliable" from a company that sent out a different product for reviews than what was available to the public? Perhaps this is how rotten politicians get reelected too!
