Hey guys,im working on another machine an Intel core 2 duo.I was going to move the 9800GX2 to that machine under XP,i set flags -gpu 5 -verbosity 9 -forcegpu nvidia_g80 but it says the machine is unstable,I have run LINx and prime,also ran Furmark for the GPU and all is fine..I have read the FAQ section but didn't find anything..This is with both cores gpu 5 and gpu 6..What am i missing here?
BTW I made sure it is GPU2 I downloaded for XP..
Thanks
the gpu flags are per machine basis. If you only have card in the C2D then you don't need flags.(if you have 2 then you need -gpu 0 -gpu 1)
go ahead and force gpu though it might help.
With the 9800X2 you will need -gpu 0 on the first gpu and -gpu 1 on the second gpu in the configs. You may need -forcegpu nvidia_g80 on the instance running on the gpu without a monitor attached. Latest drivers may have eliminated the need, but that may only be on the GPU3 client. It won't hurt anything to have it on both. You can run the GPU3 client on the 9800 series cards if you want to. You just can't run GPU2 on a fermi. Better PPD is attained on the GPU2 client, for now.
If it says the card isn't recognized, you may need to extend the desktop on to the 2nd gpu and use the -forcegpu flag. You'd probably get the same message if Windows installed the driver for the card as opposed to a fresh nVidia install of the drivers.
Can anyone tell me how to tell if -bigadv is working?
Thanks..
Also, don't forget to run through ChasR's BigAdv checklist to be on the safe side. For example, you'll need at least 10 SMP units before you get your bonus.
Edit: The checklist has been added to the super sticky.
Edit2: Also check HFM.net's historical viewer (CTRL+B); you may have already knocked out a BigAdv...
