- Sep 25, 2015
- Thread Starter
- #21
I just use Prime95 (ver 28.5 or higher) for stability testing. I have had all other tools say things are stable, but fail with Prime95 (ver 28.5 or higher).
I only run this for about 10 minutes as the first test, as this version draws about 200 W of power into the CPU.
Every other stress utility that I have run (Intel, AIDA64, Prime95 (older than ver 28.5), SETI@home, my own FEA programs, etc.) keep the CPU at 72 C with less than 120 W of power draw into the CPU.
For a given cooler setup, CPU Power Draw determines CPU Temperature over ambient.
CPU Power draw goes up as frequency squared for a given voltage (i.e. a 10% increase in frequency will increase the power draw by 21% for a given voltage).
CPU Power draw goes up as voltage squared for a given frequency (i.e. a 10% increase in voltage will increase the power draw by 21% for a given frequency).
The current overclock is at 4.2 GHz (900 MHz over stock), and the core voltage is 1.15 (I think...I'm at work) with everything else on auto.
My current gaming session is as follows:
- Run SETI@Home on 50% of my processor and both my 970 graphics cards...uses ~55% of processor and ~55% of each GPU
- Play Elite Dangerous...processor load increases to 65% to 67%, each GPU increases to 85% to 90% load
--- Processor power about 110 W, each 970 running at about 110 W each.
- Temps on processor stay below 70 C on highest core, fans on cooler running at about 67% (I can barely hear it)
- Temps on each GPU stay under 80 C with 100 MHz overclock on each GPU, fans hit about 45% to 50% (I can barely hear it)
The power draw from my rig during this session is usually around 500 W from my UPS.
After 8 to 10 hours of gaming, the temps are still the same...the fans increase but a bit, but not much...and the ambient in my home office increases about 4 C (78 F to about 85F).
When I bought the PC, I didn't spec a higher end cooler as I wasn't expecting to overclock...then I found this site!
