- Mar 3, 2005
- Central MA
- Thread Starter
- #21
Fans turned out great, painted well done!
Thanks Jolly!
Going to try my hand at sleeving this weekend, going to sleeve all exposed wires and cables.
WOW go for it! be patient as im sure you know by the results of the fans. they look great!! great coverageThanks Jolly!
Looking great there dylskee, the Sleeving and Rad look very spiffy, well done!
Those fans look really cool, has painting them affected how they run at all that you've noticed?
I wish you lived closer to me. We could have worked out a deal haha. I am too lazy to make my wires look that bad ***. I think im going to cut a corner thereWell at this point it's not a point of laziness but a giant hole in my wallet that's keeping me from sleeving every wire in this thing. I'm almost out of sleeving and I haven't found something comparable to the MDPC-X. From what I can tell you can only buy sleeving kits here in the states, if you want to buy just sleeving material the only store is in Germany. I bought a kit the first time around but i don't need everything they have in the kit this time around. I'll do some more research but this murdermod stuff is hard to beat!
bump to spur you along?
Those fans look real good. How did you take them apart to paint them?
glad to see i bring some good luck to your build hahahahLOL!! Well hit a few pot holes along the way. Been real busy around the house lately, trying to do all the projects I blew off all summer!
The first snag I hit was with my EK water block for my GTX 285, I had two different thickness thermal pads and I wasn't getting proper contact with the memory. I contacted Eddy from EK and he said somehow the wrong thermal pads were packed with my block so he mailed me some new pads.
The second issue, I ordered the wrong rev GTX 285 block the first time so I had to send it back to Frozencpu for a store credit. After he received it he ran out of stock and it's been three weeks now!! Holy ****, while typing this I just got an email notification that they are back in stock!
http://www.xtremesystems.org/forums/showpost.php?p=3985901&postcount=773
damn i think im going to have to sleve mine now too haha
your stuff just looks that much better and now i know what good is and what has been seen can not be unseen
Hey dylskee, remove the ac 97 connector from your front audio connector. It's an easy mod (similar to removing the 4 pin hdd connector from a yate loon). If you need info on how to do this i can post info.
Ah screw it, I'm waiting for dark athena to install might as well give some good info:
Okay, when you look at your connector for the hd audio you'll see wires come out and lead to a second connector. Let's face it, a nice enough case will probably never see a computer old enough to need an ac97 connector. I know my 2 main rigs are going to be purpose built so having that extra connector flopping around could at it's least be an eyesore at it's worst get in the way of some air.
Here's what you do:
What you need:
Scissors, and a pocket knife with sharp pointy tip (my gerber is perfect for this).
basically the wires are held into the black housing by metal tabs that catch and prevent them from coming out, think of it like a chinese finger trap, in that you have to push it forward, bend the tab down, and then pull back, after that, you can then cut the wires leading to the ac97 connector. If you're careful enough with this, you can come away with a slightly cleaner case and some piece of mind knowing you didn't settle for having an eyesore in your PC.
Take it or leave it, I find it's an easy and quick mod that makes a decent amount of difference when it comes to wire management, for me with an extra sound card that area is already cramped. I need to remove all the cruft I can.
