- Mar 23, 2006
- US West Coast
Ok, this is pretty much a last resort for me.
I have an intel core2 cpu (Conroe) 6600 @ 2.4GHz, 4 gigs of ram, running Win XP Pro 64. Multiple hard drives.
About a month ago after running a windows update, I rebooted and got a missing file error. Could not get the system running again and eventually abandoned my main system drive (which I believe was corrupted) installed a brand new drive and reinstalled Windows xp pro x64 on the new drive. Ever since the install, and I mean since the very beginning, my system will slow down after it's been on a while.
I used to leave my system on for weeks (or months) before I rebooted, now by about 18 hours the who system is lagging out so bad the sound effects are corrupted, programs take 5+ minutes to load or just don't.
What I've tried:
1)It's not spyware or a virus. I don't see how one could move into my brand new, reformatted by me, drive from the manufacturer and I've ran multiple programs just in case Bill Gates went nuts and started seeding them from Microsoft.
2)I've moved the pagefile off the system drive across the 3 other drives. (1.5x min/3x max)
3)I've defragged the system drive and all of the others.
4)There are no memory leaks, in fact I've yet to run a process that occupies more than 250,000k memory since the reinstal whereas before I could run a process that took up to 500,000k w/out any problems.
5)I've gone into the System Configuration Utility and disabled EVERYTHING under the Startup tab except for NvCpl & ctfmon which the system rechecked. I'm currently running on "Selective Startup".
6)I've gone through "Services" looking for anything that appears remotely non-essential and switched it to manual.
7)I've disabled automatic updates
8)It's not Windows Defender - I've had trouble with that in the past sucking up resources, it's not even installed.
9)I ran OCCTPT (a cpu test utility) for 14 hours under heavy data set - found no errors in the CPU's. Ran it again when the system was running very slowly (after being on about 24 hours), again no errors found.
10)I've tried multiple reinstalls of the OS, just in case there was something I managed to *&$@ up but there appears to be no effect.
11)All drivers are updated, along with Windows.
When the system starts to slow down, any program I attempt to start up will use only 50% of the available cpu (usually) as seen in the processes tab. But the system will be crawling. The more I use the system the faster the slowdown occurs.
Only weird thing I can't explain (because I don't know enough about 'em) are the handles. I usually have less than 30 processes going, threads are around 350, but last time I rebooted I noticed the handles were over 16,000. I don't know if this is high or not. At the time of the reboot, I had no programs open so I don't understand why there should be so many handles.
Anyone have an idea?
What I've tried:
