Just got my thermochill pro water cooling kit and had a look at the pump.
Its an Ehielm 1250, the first problem is that the tubing supplied is 1/2" tygon tubing but the adaptors on the pump are not the same. the horizontal outlet is a bit larger than a 1/2 and the fit is very very tight ( quite reassuring actually ) but the top outlet is a 1/2 fit but its only about 1cm long so the tubing goes on but feels loose. Should the outlets be the same size? I have read somewhere about elheim pump adaptors but as i bought a kit i thought it would come with any required adaptors?
Also its quite loud and vibrates in the bottom of the case. Even when secured firmly it buzzes and hums. Is this normal?
Thanks
Thanks
