- Dec 27, 2011
- U.S (ga.)
Now, lets put some pics together to see the big picture from CPU-z as wacther sent me a pic of the "SPD" tab by email.
The timings look appropriate for the frequency but with some manual fine tuning of the timings you can probably get better performance out of the memory as you can see by comparing the SPD tab XMP-1600 column timings with your current bios settings as displayed in the Memory tab. Smaller numbers means tighter timings and better performance. Watcher, I am assuming you have the memory timing and voltage on "Auto" in bios.
Core temps and CPU temps look appropriate at stock frequencies and voltages for his Hyper 212+ cooler.
If you're wondering why your CPU is showing as quad core, it's because your CPU is a quad core. I believe some can be unlocked to hex core, so there are probably some BIOS settings for unlocking cores. However, I don't know what those settings would be since I've never owned an AMD CPU or motherboard.
It's kinda hard to tell what, if anything, you are asking about since there are no questions in the OP.
