- Apr 6, 2012
as the title says, im trying to make my cpu to 3.8 ghz, im at 3.7 1hour prime-95 stable, but as soon as i try going to 3.8, my pc crash (blue screen) even if i put the vcore of the cpu higher...
here are my setup and settings:
Antec 902 tower
Asus crosshair iii formula mobo
Amd 965 BE 140w cpu
Ocz plat 1600mhz ram
2x 750gb WD caviar black in raid-0 HDD
Ocz vendetta 2 Cpu cooler
Ati radeon 4890 vid card
here is some bios settings that are 1-hour stable.
My maximum cpu temp is at 49 celsius under load, and NB temp is 38celsius max.
im using a cpu core voltage of 1.4v in bios, but on everest its right for the idle, but when i run prime95, it goes up to 1.44-1.45v. i tried to put the voltage in bios to 1.45v (to get 1.5v under load) but @ 3.8ghz the computer crashes.
i read a lot of different oc builds, and read the guide o this forum, the NB clock should be 2400mhz with 1.25v to be stable at 3.8ghz, im using a nb of 2600mhz @ 1.30v and its stable @ 3.7ghz
Antec 902 tower
Amd 965 BE 140w cpu
