- Apr 14, 2011
so i am trying to reach 5ghz on air and testing with prime95.
when i run max fpu stress, temps go up to 90-95 (which i drop right there). when i tested again with my 4.5ghz overclock, i found it did the same thing. so the max amount i could get was 4.2 the cooler i have is an NZXT T20.
would buying a bigger heatpipe cooler help me achieve this? if so, which one should i buy? i was thinking of getting the nzxt havik. i want to do this only on air and using the lowest amount of voltage possible. i will be using prime 95 to stress test and Natural selection 2 to test for stability).
