- Apr 14, 2011
- Thread Starter
- #21
with [email protected], you'll never make 5GHz (or 4.8GHz+) without de-lidding. Even under water.
Mine does [email protected] and before de-lidding, it was hitting already 90°C+ at this freq/voltage with a NH-D14.
so after disabling c-states (except speed step and C1E) i got it down to 1.200 volts at 4.4ghz. did not crash in ns2 and the temps were still kind of the same, but mostly around 78 in the beginning. oh, and this is all on offset (0.030-)
ill see if i can get it down even lower later on. i tried 1.185 and it crashed but at 1.190 i dont think it did...i think ill check again today.
5ghz is a hard look, I'm running mine at 4.8ghz at 1.25ghz on a CM V8 and It will hit 80C+ in P95 testing. I can't go any higher without increasing the vcore.
what cooling are you using? is it something like a noctua? water?
I hit 5GHz in a trophy run. I have a screenshot to that effect, but when I went to CPU-Z all I got was 4999.96 MHz.
I would never run I faster than I can dissipate the heat under AVX2. With Linpack without AVX2 I can run it hotter. My D14 did not seem to matter when AVX2 was involved. So I'm using my Armageddon, and a much lower OC. I think 4.4GHz is as much as you would want to push a chip that has not been delidded.
what tempatures were you at when you reached 5ghz?
