can some one tell the most difference between Masterkleer (0.50$ / foot) and tygon (3.00$ / foot) ...
About 2.50 a foot
It still makes me wonder why people would spend $60+ per water block, then decide that $3/foot is too expensive for tubing... It's not like we use 20ft of tubing in these things. If you bought the 'best block' and 'best pump' for your loop... buy the best tubing. Otherwise you are doing the equivalent of bringing a Ferarri to Maaco when the paint gets scratched.
Very cool, thank you!I have no idea if it kills the type of bacteria in our loops. I buy deionized water, take the silver wire that has been pre-sanded to remove any oxidation (does silver even oxidize?), and let the rod sit in there for several weeks to months in hopes of ions being taken up by the deionized water. I just use that a few months down the road with the other wire already in the loop.
Very general info:
http://www.fraunhofer.de/fhg/Images/magazine1-2004-48_tcm6-10184.pdf
"They destroy the enzymes that transport cell nutrients, weaken the cell membrane or cell wall and cytoplasm, and disrupt cell division and proliferation processes. The bacteria are unable to survive this treatment. Silver coated medical instruments and devices thus remain germ-free."
http://www.edc-cu.org/pdf/Silver Paper.pdf
"Vikings would line the hull of their ships with strings of silver and copper to prevent growth of algae and barnacles. Notably, modern ships still use silver and copper for the same purpose (Laubusch 1971)."
http://www.epa.gov/oppsrrd1/REDs/factsheets/4082fact.pdf
"Silver also is used to control several types of algae in swimming pool water systems"
http://www.lenntech.com/water-disinfection/disinfectants-copper-silver-ionization.htm
"Well water containing copper and silver coins is very bright, due to the biocidal affect of these metals."
About 2.50 a foot
I know silver kills bugs. The hospital I work in has silver door handles to kill bacteria on your hands before you enter the room. Thus the silver efectively prevents spread of disease. (yes its costly but less sick people saves us money in the long run)
Yes I have also proven the effectivenss of silver in water cooling. I did these tests a long time ago the pic shows that nothing grows around the silver and copper pellets.
You dont have to constantly pay 30 bucks for tubes you only need a small segment of silver tube and you will be maintnece free
You should have got silver tubes not black, now with black tubes you can see the bacterial growth and you will never know if its there or not (unless you have a clear res).
The problems may arise from the use of anti-freeze, which tends to coat copper in a thin film of "protectant". No AF, no film, maybe no bugs ...???(Reality is there are people out there with copper water blocks like the storm and they still suffer from growth).
Wouldnt it be cheaper to make copper door handles in our hospital? We chose silver for a reason...
(no not caus it looks better)
