QuietIce
Disabled
- May 7, 2006
- Anywhere but there
I've got an idea. Instead of using silver and copper in the dish why not use a bit of Silver Tygon and a bit of R3603 - maybe a 1/8" long "ring" of each? And since your loop has been active for awhile, doing a bacteria test(?) on your water might be interesting.The rad is made of metal and over time it would also increase the conductivity of the water.
Silver tubes block out the light that algae use for photosynthesis.
Silver kills bacteria (kinda proven in both literature and in laboratory tests)
Does iodine kill algae (we dont know)
Yes it kills bacteria but how much iodine do you need? (some say 1 drop some say 10 drops)
I know voigits says iodine and algacide is cheap stuff like 2 bucks a bottle.
But then again silver tubes cost only slightly more than regular Tygon R3603.
I have used tygon silver for a long time now, thus far I havent changed the water and its all crystal clear... (voigits you know Ive had these silver tubes for ages)
As for how much iodine is required - according to the University of Missouri it's 0.05-0.1%, so for a "standard" loop (~ 1 qt. of water for internal or mostly internal) one cc of undiluted iodine should be fine (5-10 drops of Tincture of Iodine). Another source cites 8 drops for common Tincture of Iodine and 4 drops for common Povidone-iodine per quart of water.
Note the University of Missouri clearly states (more than once) that iodine is NOT an algaecide ...
