- Jul 12, 2002
Just upgraded to a 5900x and looking to do some tweaking to minimize/elimininate the following...
1) CPU goes up and down by simply opening up a program etc. Hopefully this makes sense? I open an app and the temps go up by 15-20 celcius, fans spin up, then within seconds they go back down and etc. I'm using AMD balanced power plan.
What I've done so far is put in a -30 curve optimizer and - offset voltage of 0.1000 I ran both the OCCT and Cinebench to see if it's stable and it is. I'm not even sure if I can use both the -30 CO and -offset voltage at the same time or do they conflict with one another? The info I've read is unclear.
I don't mind a small decrease in performance but with the -offset I got a Cinebench score of 16000+ vs 21000+ without.
Ideally, I'd like to tweak another BIOS feature.
Now I know what you're thinking. Why not just create a fan curve that doesn't go up/down due to the cpu throttling up/down.
Ideally, I want to stop the CPU from doing what it does. There's no reason for it to go up that high, just to open up an app.
Thanks.
Thanks.
