- May 23, 2009
- Houston, Texas
Hello forum, I recently decided to give AMD another go and got an AM3 phenom II x2 545 Calisto stock core is 3.0GHZ. I've been playing around in the bios and I've dropped all the values, cpu multiplier x5, HT x3, mem clock down all the way to x4.0 which is still 1000mhz, DCT's unganged, ram timings I've left alone as it's reported as CL-9, which I take for 9-9-9-24, but I can play around with them later, pretty high though, I guess that's what the cheep stuff gets ya, it's DDR3 though. Back on track, I've started pushing the FSB at 200, and worked my way up to 255, but now prime 95 is throwing rounding errors. So I'm figuring my FSB is not stable above 250. I went into the voltages portion of my bios to push the Northbridge .01 and it failed to boot. The obvious settings for the voltages are auto, and manual, but as soon as I check manual it starts flashing system voltages are not correct, however all the options are set to normal, so I tried pushing the northbridge +0.1, and it failed to boot. I've checked my mobo user manual and nothing on default voltages, but even then what do you do when your options are normal, or +, -?. I'm not an advanced overclocker but I'm learning, and seeking advice here, as it's always top notch. I do know if I can't increase my voltages without a catastrophic failure occurring, I won't see much and O/C. So any advice out there would be of great benefit and greatly appreciated.
CPU: AM3 Phenom II X2 545 3.0GHZ
MOBO: Gigabyte MA785GMT-UD2H
RAM: 4GB, 2x2GB 1333
