ok im having a multiplier problem i want to lower it and raise the fsb to 200 and when i try to lower it manually it says !warning cpu may be over speed, any idea how to fix this? i have it set to auto multiplier and i just raised the fsb to 185
On the Main tab in the bios, change the "Halt On" to something other than "All Errors". That one was stopping me for a bit also also
I have something strange when I change the FSB by even one notch up or down. If I go to the Exit tab and do the "Exit & Save Changes", my PC just hangs and never reboots. I have to power down and then things work fine when I restart. I reflashed back to 1001C and still have that small issue.
i flashed to 1002 and i can change multi fine now, only problem is the ram now i think. i upped the voltage to 2.8 but my screen likes to blink every once and now =/
