- Dec 10, 2012
- Washington
Good afternoon to you all!
So, I finally got fed up with my E4600 (1.512v for 3.3Ghz?) and popped my old E4300 back in and messed around with it. I was never able to get past an FSB of 333Mhz, but I realized that my RAM was being OC'd too, and wasn't able to cope with the speeds it was at. So, I lowered the speed ratio, and managed to get all the way to 4.581Ghz at an FSB of 509Mhz (on stock voltage and air cooling )!
The issue is, at 510Mhz, the whole system refuses to post. It tries to boot up about 6 times, then POST's with a "failed overclock" warning, which defaults you back to the stock settings. at 509MHz, the whole system is perfectly stable, Prime95 for 6 hours and the whole system is running beautifully.
Would messing with the timings have any affect on the stability of the RAM, possibly enabling the OC to go higher? Could a modified BIOS that further reduced the ratio help? My motherboard doesn't allow RAM voltage changes, sadly.
Thanks in advance!
Thanks in advance!
