I'm not the most experienced overclocker, but I think I just got lucky.
I purchased an ASUS M5A78L-M LX PLUS motherboard and AMD Phenom II X4 960T Black Edition combo for $150 (eBay).
I also picked up CORSAIR XMS3 8GB (2X4GB) 240-Pin SDRAM DDR3 1333 CMX8GX3M2A1333C9 for $48 (eBay).
In the bios I disabled Turbo, Cool'n'Quiet and Q-Fan.
Then I enabled ACC and turned on Unleash Mode (all cores).
6 cores unlocked.
Used HWMonitor and CPU-Z for monitoring.
At this stage CPU-Z identifies the CPU as 1605T.
Ran Prime95 Heat stress test, no problems.
CPU (core temps cannot be read while unlocked AFAIK) ran out about 57c under full load with stock cooler.
So then I grabbed a Cooler Master v6 from NewEgg for about $50.
It's so big, my case won't close anymore, so running with door off.
New CPU temps were low 30s at full load w/ Prime95.
After some reading and experimentation, I went back to the bios.
I turned CPU Overclocking to manual.
Set CPU Overvoltage to 1.45.
Set Multiplier to 20x.
Now I'm at 4ghz w/ 6 cores.
New CPU temp at full load w/ Prime95 is 47-50c.
Ran through 3DMark06 with no problems.
At this stage CPU-Z identifies the CPU as 1600T.
Left it running overnight defragging the main drive (not running Prime95, wasn't that brave yet).
It seems stable and idles at about 35c and maxes out at about 50c.
I will run an overnight Prime95 test soon.
With all fans at %100 it's pretty loud, but I don't mind.
Best birthday upgrade yet!
This little upgrade may warrant a new case.
Not sure I want to push the limits any further considering this is a pretty sweet spot for this chip.
Is there anything I should watch out for with this build?
6 cores unlocked.
