- Aug 5, 2002
CPU: E8400
ES/Retail: Retail
Batch #: Q743A756
Ship/Packaging Date: 12/27/07
Voltage(s) (Stock/OC'ed): 1.06V CPU-z(1.2V Bios)/1.21V CPU-z (1.37V Bios)
Frequency(ies) (OC'ed):4050Mhz+ (still going)
Motherboard: Abit IP35-Pro
BIOS: Beta 16.04
*Extra* Memory(ies) (Timing(s)): 5-5-5-12-42 (Currently only for testing)
*Extra* Memory(ies) (Voltage(s)): 2.2V (Currently only for testing)
*Extra* Third Party Cooling Solution: Thermalright 120 Extreme w/ 120mm Sthyce Fan
*Extra* Paste(s)/Compound(s)/Other(s): MX-2
*Extra* VID: 0.975
Just got it, not sure what the temps are on it since with Core Temp 0.96.1 it reads 42C and with 0.95.4 it reads 37C constant :/ Guess thats Vista 64-bit working right there hehe or the bios which ever it is, wait wait I see 43C spiking on the core at stock speed. Not sure about the temps though its cold in here 64F currently so I should be safe to play with the OC, going to crank her up here in a sec.
Hey HousERat, look at that batch numbers very close to each other only 8 away.
Edit: Updated 1-24-08 7:16PM
Still running got it up to 4.05Ghz with some playing on the memory settings since thats what killed me before. CoreTemp finally started giving me readings at 3.6Ghz with 1.3V set bios I was getting 44-48C and now with 4.05Ghz with 1.37V set bios im getting much closer temps at 51-53C. I like it Warmer than my other chip but also much faster so what can I complain about I'll do prime testing here over night if it works at these settings, then work on it from there since I want to game a bit tonight
ES/Retail: Retail
Batch #: Q743A756
BIOS: Beta 16.04
*Extra* VID: 0.975
