Hello everybody! I'm new the forum and thought that as a first topic, I would ask for some upgrade suggestions. Basically I'm just looking for some recommendations on what I should upgrade now and what I should upgrade later.
Budget Range: I'm going to say my budget will be around $300. I may push that to $400 if I really think that it's worth it.
System Usage from Most to Least Important: I use this PC for just about everything, however the primary focus is gaming. Web surfing and movie watching are tied for 2nd place.
Current System Components:
OS: Microsoft Windows 7 Home Premium 64-bit SP1
CPU: AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz (http://www.neweggbusiness.com/Product/Product.aspx?Item=N82E16819103849)
RAM: Kingston (2 x 4GB) DDR3 1600MHz/Patriot (2 x 2GB) DDR3 1333MHz (It’s either that, or vice versa with 8GB 1333 and 4GB 1600. I had a mix up when buying ram a year or so ago and accidentally bought 1333 instead of 1600, but installed it anyway and currently run 13GB @ 1333Mhz)
MOBO: Gigabyte GA-890GPA-UD3H (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435)
GPU: Sapphire Radeon HD 7870 GHz Edition OC 2GB 256-bit GDDR5 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814102983)
PSU: APEVIA ICEBERG 680W (http://www.newegg.com/Product/Product.aspx?Item=N82E16817148028)
HD: Seagate Barracuda 1’TB 7200 RPM SATA Hard Drive (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433)
OD: ASUS 24X (http://www.newegg.com/Product/Product.aspx?Item=N82E16827135221)
AUDIO: Rocketfish 7.1-Channel PCI Sound Card (http://www.rocketfishproducts.com/products/computer-accessories/RF-71SDCD.html)
CASE: NZXT Phantom Full Tower White (http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067)
MONITOR: Dynex 40” 1080p LCD HDTV @ 1920 x 1080
Preferred Website(s) for Parts: Wherever is cheapest and despite breaking the "PC gamer code", I don't mind buying used parts as I have in the past and have had great experiences with it.
Location: Browsing a few topics, I see that everyone is really into Microcenter. I live in Dallas, Texas and there is one about 20 minutes from me, so that is good news.
Parts Preferences: Doesn’t matter to me, I just want the best bang for the buck. If it came to a tie between Intel/AMD or Nvidia/AMD, I would side with AMD.
Overclocking: I do plan to start overclocking, but for now I am studying guides on the best ways to do it.
All suggestions are welcome! And I'd extra appreciate an order in which I should upgrade my parts with some suggestions for each! Thanks.
