- Oct 21, 2017
- Your local chemical plant
My current NAS and it's drives are getting to old for comfort (and to small with its current 8 Tb), hence I am on the look out for something new.
However after some searching around I became even more confused as I was before (network is not my expertise). My current NAS is also incompatible with Plex and my Samsung smart tv.
Primarily I want to replace my NAS and if budget allows it a stylish htpc.
I have a budget of around €350 in mind excluding HDD (wanted to start out with 2x 8Tb in raid 1 and add another 2x 8 Tb later)
At the hardware level I am abit conflicted with what to choose and if a low power consumption NAS might also be suitable for a htpc?
My current build idea:
AMD A8-9600
Asrock A320 pro 4 uATX (cheap, ECC supported memory and has plenty data 600 )
16 GB ECC 2400 MHz compatible memory
Seasonic S12-II 450W
Kingston A400 120Gb (boot drive)
Any decent looking uATX case with 4+ 3.5 drives.
The support for ECC is limited on the Asus and Asrock boards I like, any better options? Do I need ECC at all for a simple NAS/HTPC?
What kind of OS is recommended? I want to use Plex for media streaming.
AMD A8-9600
