- Sep 13, 2015
Hey locheckey i was ready another thread you posted in and you said you had a build that could dissapate around 900w of heat, what is that and do you have pics of that? would love to see what that is
I can get some pictures if you like but it is nothing pretty it is just my benching setup. It basically relies on a large 1260 radiator with high speed fans. This is not meant for an everyday system as it is very loud. The other thing to note is that when I start putting a large load like that on it the delta T goes to like 10-15 degrees C.
If I'm looking at your case right it looks like you could fit another radiator on your main section. If it was me I would either move your 240 there and mount a new 360 on the left side or mount the new 360/480 to the center section. I would then series the entire loop to include the cpu and gpu instead of running 2 loops. This will allow for optimal cooling off whatever component is being stressed while providing adequate cooling while the whole system is stressed.
