boodaddy
- Jan 3, 2016
Hey Guys,
I am getting the Nexxxos Monsta 480mm Radiator http://www.performance-pcs.com/alphacool-nexxxos-monsta-480-radiator.html
Problem is it takes 4x120mm fans, and for some reason I had thought I can put 4x140mm fans on it. If I purchase an adapter like this one http://www.frozencpu.com/products/9...er_-_Clear_BP-FA140120-CL.html?tl=g47c121s262 or possibly this one http://koolance.com/120mm-to-140mm-bracket-adapter
will that work?
I am concerned that the cooling will be compromised doing it this way. I have tried to change the order, but Newegg already shipped them. What's your thoughts. Would this work? Would this mess up efficiency? Any help or advice would be much appreciated. I appreciate your time, and advice.
Thanks!
will that work?
Thanks!
