- Mar 14, 2005
- Niagara, ON
I was cleaning out my basement room, and I noticed that my keyboard hadn't been cleaned since I got the G15 (3+ years ago), mostly to the disgust of my girlfriend, I decided that I should clean it. So I got a cloth for LCD screens and wiped it dow, but it wasnt doing anything. So I asked my dad if the air compressor had some air in it, and it did. But I plugged it in to charge it, this is maybe a 3 gallon portable air compressor, and was using it while charging it. At 50PSI it cleaned the keyboard back to new (minus the small wear and tear), the keys no longer are hard to press down, there is no hair, crumbs, or miscellaneous previously-floalting objects found underneath the keys and I am happy.
Now you are asking, what the hell does this have to do with watercooling? Well stop asking questions and I will tell you
I then decided that I should get the old computer into the garage and blow the hell out of it (yeah, I said that on purpose). I set the compressor to about 60PSI and let the thing charge to get the tank full, and slowly I blew the crap off of every fan, component, compartment and of course my rad. It took maybe 15 minutes, with 2 interuptions, 1 from my neighbour who was curious as to what the hell I was doing with a giant tin box. And my buddy came over to show me his new 1TB ext HDD and grab a copy of Windows 7 from me.
And the difference, well besides the fact that it is really really clean, and I probably put out about 3lbs of dust into my neighbourhood (note: make sure you have a fan blowing the dust away from you, or it wont really go far and might just stay in the case) the temperature difference is amazing.
Components
MCP-600 > MCP-600 > Cathar G4 (modded for Socket 1366) > BIX3 > Dual 3.5" Resivoir
Fans: 3x Sanyo Denki Metal Housed 24v fans @ 12v pulling air through the rad and many more throughout the case
Previous temperatures
Idle: 33C
Full Load: 60C
Current Temperatures:
Idle: 28C
Full Load: 43C
Yeah, cleaning out my rad and system fans managed to net me a drop in temperature of 5C on idle and 17C on full load
So since it is nice out now, in Canada, so everywhere else (North America, unsure of temps in other areas) better be, CLEAN OUT YOUR SYSTEMS and watch as you help breathe new life into your cooling.
Components
Idle: 33C
Full Load: 60C
Idle: 28C
Full Load: 43C
