- Jun 9, 2017
It has been a while since my last post on a computer I built for a friend which is water cooled with a Corsair H115i All-in-One. As I built it, everything worked just great. However the friend is trying to work with gigantic Excel workbooks, and does quite a lot of video editing, and too many times it felt slow to her. I would get complaints when Excel froze up. (I did strongly suggest that Excel has its own issues once you do too much formatting and too many pivot tables, but that is a different subject for some other forum, smile.)
All this time I've been itching and itching to use an EKWB water cooling kit, and an EKWB water block for the graphics card. I decided to replace the processor with a more powerful Xeon processor. This was my excuse to also try the EKWB kit and graphics card water block.
After much work, I've installed the kit. It is not too bad. A photo of the system being leak tested is shown below. I'm still leak testing as I write this. I could not find any place inside the chassis to put the reservoir and pump so I put it on top of the case. It seems to be working -- at least, there is no leaking water to this point.
I admit it is probably very amateurish, but it is a great experience for me.
Earlier this week, I had wondered if the 2 meters of EKWB-brand tubing would be enough for my system. On Tuesday night, I decided to order some Mayhems brand tubing from ModMyMods.com. They posted it to me the next day. Meanwhile, I took Friday off work to do this modification of my friend's system. It took many hours for me...and I made first-time, new technician type mistakes when connecting the EKWB tubing. I kept cutting it too short or too long and I'd get kinked tubing. Well, Friday afternoon the package with the Mayhems tubing arrived. It saved me! I'm using the Mayhems tubing for the last part of the cooling loop. Had I not ordered it as a backup, I'd be out of tubing (due to my own mistakes) and have a disappointed friend.
The hardest part of the entire build for me was figuring out where to put the pump and reservoir. The second hardest part was installing the water block on the graphics card.
Thanks a ton
Bob
Thanks a ton
Bob
