My CPU is i7-6700K running at 4.7GHz. RAM is HyperX Fury 2x8GB 2666MHz. I was overclocking the RAM to 3000MHz with 1504 Bios. I found a setting which was running fine. Then I wanted to further optimize Refresh Interval and REF cycle time of the RAM at 3000MHz. Bios was set to enable RAM training (MCR fast disabled). RAM training seem to have destabilized the settings, even the settings which originally worked at 3000MHz.
As a solution, I cleared CMOS and took the opportunity to install the latest 1601 Bios. First run at CPU 4.7GHz and the RAM at 2666MHz XMP, with RAM training enabled. Everything works fine.
Question: I gradually want to increase RAM to 3000MHz. When I do this overclocking, should I keep the RAM training enabled or disabled (Bios setting MCR fast)? Or keep it enabled up to a certain speed e.g. 2800MHz and disabled at a higher speed?
