this is what i have and both the leds and uv lights are BRIGHT!
https://www.amazon.com/gp/product/B01MZWKOT4/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
sorry man my rig is in the process of being relooped so my psu isnt hooked up. i tried jumping my back up psu but the controller wont work right that way. i dont think its getting enough juice. ill try to get my loop refilled and put back together tonight tho.
after trying different placements with the strip im going to get another 30 or 60cms to make it go around the case more completely. with your 900d youll probably want to get a couple 60cm if you decide to go that route. 60cm alone just doesnt do it.
You probably got the cheap UV LEDs which are like 395nm or so and are only just getting into UV. You'll probably want 365nm or so for "true" UV. Even shorter wavelength LEDs exist, but I wouldn't recommend them for your application since such UV can be harmful with extended exposure.
