Larger tubing so I guess 3/4, I've ordered an angled one so hopefully that will solve the issue.yes you could use an extender and a angled fitting
that looks like all you can do barring getting smaller tubing
What are you running 1/2" x 3/4" ?
Stuff like this you don't expect until it happens.....next build in 5 years I'm going to match brands [emoji23]That should get you out of the woods
I am petg tubing my PC and I'm stuck with my CPU block.....the fittings won't fit next to each other on it? I've never had this issue before....do I need to buy smaller fittings or am I doing something wrong?
Not sure man but I fixed it just by using an angled adapter for one of the threads. The brand I used just had thick outer parts of the fitting nothing to do with thread size. Just buy an extension or angled one to be safeHey bro,if i use that cpu block with g1/4 3/8 1/2 fittings will i have that problem?
2700x? Yeah goes good man no issues paired with a 2080tiOK mate thanks, how does the cpu behaves?do you like it?
Haha CPU block is good kinda wish I got RGB one though. My loop is very quiet so under full GPU load CPU sits at 65 degrees in heavenI edit the post bro, i was refering to cpu block, sorry =)
Sweet as post pics when you're done and watch a few vids on applying thermal pasteYeah i was looking for the RGB one =). Ok bro, thanks. I´m building my first watercooled system =)
