- Feb 20, 2007
Heya guys.
I am having a very very weird problem with ventrilo.
This might be a bit long, and I will add extra details at the end.
The main problem is with the sound output. Many people in vent tell me that when I speak, or even dont speak but push the "push to talk" button they hear a very fast "slapping" sound superimposed over my voice (or by itself if not speaking and pushing the button). I dont want to get graphic, but the sound creates major uproars of laughter because it sounds like what you would expect to hear in a movie from a man masturbating. Hey I know...but that is the common descriptor that I am told it sounds like!
The funny thing is, it ONLY happens when using my USB microphone. When I plug in a mic to the pink plug in my on-board sound on the mobo, or on the front panel sound everything is fine.
My system was originally:
Foxconn Mars, X3220, 4 x 2gb Mushkin Extreme PC8500, 2 X 320gb Seagate Barracuda 7200.10 perps, and a GTX 285. I was having some other issues with that system (other USB ports not working 100% properly - ie mouse needed to be replugged in usb port after reboot for it to be recognized) and just this weekend had windows issues with certain files not being recognized and not allowed windows to boot as well as corrupted Prefetch or other files. OS is XP x64.
So....I went under the assumption that my mobo had gone bad based on multiple USB problems, and other wierd issues. I have used this motherboard in the past for subzero benching so I just assumed its time had come.
I redid the system this weekend my replacing the motherboard with a P5K deluxe and a E8600. Reinstalled windows, and kept the HDs, memory, and GPU.
After all is said and done I still have the same damn issues!!!! The mouse does the same thing, and more importantly Vent still has the slapping sound!!!
Im experiencing other issues with this computer (tried to install Vista Ultimate x64 and it took 5+ hours to install and do updates, and now with the XP x64 install it hangs in all sorts of weird areas - no reboots and no freezes but takes FOREVER to install or open programs) so my next guess is perhaps a memory problem and I will be running Memtest 3.5 today to investigate that as a potential cause. The more I think about it the corrupt files and "missing" windows files smells like a memory issue, but I cant personally correlate the mouse or USB issues specifically to memory nor can i make a correlation to why the mic works with pin connection but not USB?
Any suggestions on the weird vent sound issue though? Why do you think it happens on a USB mic but not on a pin connection into the pink outlets? I have tested the mic in question on another computer and the sound is gone.
Do you think that the weird sound could be from a bum memory stick?
Some vent setting is off? Codex or something?
Any suggestions appreciated Im pulling my hair out over this. I would use my other mic (pin in pink connector) but this is obviously a sign of a problem that I want to resolve, and the other mic is very soft and a PITA to work with.
TY in advance for any advice.
