Alright so i just got my water loop mostly done. Im waiting on my GPU blocks from EK. everything fits and runs fine... if the plastic top of my case is off. If i put the top on, everything starts to power on, the lights on the fans get bright, fan contoller shows that they are seen, and then they dim, fan contoller doesnt see them(led turns off) and the system gets quieter, then starts cycling that symptom but wont post. if i take the top of my case off it boots fine into windows, everything is good. if i put the top back on, I can hear and see(because of the fan's leds) the fans slow down again. the two fans sit just below the grille of the top cover. Im so confused by this. unless the fan controller has a safety check im at a loss. The fan contoller does not communicate with the MOBO. Any ideas?
