For the Vdroop mod, you need to use a variable resistor. The value resistor that you need to use will depend on the Vcore you are running, the speed the CPU is running at, and even the temperature to some extent. There's no problem with using variable resistors for the mods, as long as you use high quality components, make sure the mod is done well and properly insulated against short-circuiting.ochungry said:jonspd, before i do any of these mods, I wanna find out what resistor gives what, because i dont like VR's, they are not reliable and prone to accidental high voltage.
I would just install a single resistor for fixed voltatge, or build me a little variable resistor board to adjust the ohm.
Edit:
jonspd,
jame asked me in "new asrock" thread so posted there.
But basically: I replaced the 890 ohm "droop mod" w/ 1k and vcore fluctuation is still there but not as much. before the 1K I had tried 2.42 K but no post. Next I am using a 1.5K. all fixed resistors(NO VR for me).
Now I am building me a pin socket w/ resistors as a homemade VR.
I tore off IDE socket from an old mobo and am soldering resistors w/ different values to the pins extruded in the backside. some are in series and some independent. also have 100 ohms for decimal final values. with this I use a jumper (or 2-3 together) to short the pins and get the resistor value I want. sort of works like a VR, but much safer and steady/accurate reading.
Replacing the stock Vdroop resistor with a higher value will increase the voltage drop under load. At stock, the board I've got here tends to increase Vcore under load, which is why I said to replace the resistor with a variable resistor, instead of connecting one in parallel with the existing one (which would only have the effect of being able to decrease droop). The stock value of the Vdroop resistor on my board was 1.2k, which could be why it overvolts, if yours is 890ohms. My board is rev 1.04 (iirc), if that makes any difference
Vcore will also increase as you increase the Vdroop resistors value. Using a 2.4k fixed resistor was probably sending the Vcore regulator into either overcurrent protection or overvoltage protection.
When you have done the mod, you will need to check the ammount of droop with a DMM. Software readings aren't accurate enough to be able to show the ammount of droop properly. I'll try to get a picture showing where to read Vcore from later today
If anyone has any questions about any of the mods here, feel free to PM me here or at xtremesystems
