- Jul 27, 2005
- Austin, Texas
voltmod update
Ok, I went to radioshack and bought a 2x3 breadboard ($1.95) and soldered 2 sets of resistors. One set for the vdd and the other for vcore.
I have already done VID3+VID5 mods, but this time wanted to see @ what resistor value I can get rid of vcore fluctuation.
I had a feeling, the resistor value need to fall somewhere in the middle of the FB reading, and not the edges. What I mean is that the vcore controller has an accuracy of .5% that can fluctuate 16-32 mv.
Instead of being close to the edges (near 16mv or 32mv) I wanted to find out how much ohm needed to put it right in the middle (16....middle....32).
I soldered on the breadboard a 25K w/ 10-100 ohms in series. this gave me 25.1, 25.2, 25.3.... so on. Soldered some pins. Stripped an IDE cable and used individual lines and soldered header to one end(to push in the pins on bread board). Attached one end to 25k leg and soldered the other end to the cap (as shown by Rebel's mod) soldered the other wire to ground and a header on the other end, set my vcore to 1.275v(1.50v actual) and checked vcore from 100 ohm end(26K total in series) I found 25400ohm(25.4k) less fluctuating than below or above it. I guess I am very close to that middle point was looking for. I am thinking to divide the resistors to 10ohm interval and check vcore w/ smaller fractions.
Now about the vdd: I did the same thing w/ vdd, but only used 1k ohms up to 9K(in series) and used 10-100 ohms to end up w/ a 10K VR.
The vdd without the mod was @ 1.99v, and gradually raised it to 2.07v using 6.7k resistor. don’t want to go higher than that for now. I also found the middle ground for 2.07v vdd. from 6.4-6.9K vdd stayed the same. so I chose 6.7K.
Both mods are on the same breadboard. I guess you can call this breadboard a VR board, that is more accurate than a trimmer, no chance of overvolting by accident, and can know the resistance values.
Edit: I went to bios and lowered the vcore one notch to give me 1.58v. came to window and CPU show a bet more fluctuation. I lower my BD VR(breadboard VR) 100ohm and vcore stabilized.
Let me see how I can explain this. I guess the vcore regulator .5% accuracy does not exactly fall right on 25mv vcore increase. it has a 32mv range and 25mv increase will have some values left over(32-25=7mv) for the vcore 25mv increments. so I have to adjust the BD VR to compensate for that 7mv difference that may fall below or above the bios vcore adjustment.
I think this explains it why I had to decrease another 100ohm to make vcore stable as previous setting was. I really think If I solder a few 10 ohms and use smaller fractions the vcore might be more stable.
What if I solder a 1uF cap at each pin...hmmm?
I might do that. hope don’t fry the regulator. If you don’t see me post here for a good while, chance are I don’t have a mobo to access internet
Oh another note: there is still a bet of fluctuation. But very little and only jumps up 16mv and quickly adjusts. Much better than before that was 32mv and constantly up and down.
Edit2: I un-soldered a 10uF capacitor(small cylinder shape) from an old mobo, and soldered it between the 100 ohm resistors (grounded the ground end) and now the vcore is very much stable. It just fluctuates 16mv once in a while up and right back. Because the cap is 10uF, It takes about 10 minutes for vcore to stabilize. I guess it needs to fill up.
