- Aug 14, 2014
So as the title says I want to put a fan on my VRM's if possible, don't really like them hitting low 80's, problem would be the Noctua, will it disturb the flow from the block -> back fan ? I'm assuming I have to set it to push air into the VRM's which will be at least "tepid"...
If I can't do this for some reason, what kind of fan would I need to put on the back of the motherboard ? I would like to keep it fairly silent, can I use one of my fractals 140mm for any meaningful gain ? My setup as it is is dead quiet with the fan profiles on standard. Mind you it will be literally on top of my 2 SSD if it makes any difference.
Check signature for details, will attach pics if needed
EDIT : just noticed i put this on the wrong section, can someone move it to Cooling ?
