- Feb 12, 2005
- Michigan
I've got the exact same rad and pump you're getting, you won't be dissapointed in the least. That pump is so quiet.
you need fans??? Jk lollooks good.. will easily handle a cpu.. fans?
lol just didnt see you mention them at all!
so pt nuke and distilled water was my first choice and some blue coolant to make water blueunless you are going to spend $$$$$$$, and i mean major $$$$$, then the your best bet for performance is distilled water and an anti-algae, like pt-nuke. the only time you need something else is if you are mixing aluminum and copper. then you should get an anti corrosive, since the two will form a galvanic cell and corrode one another.
i know for me, (as you know rumy, that i just finished building my system) that the week of waiting for parts is the toughest!
one piece of advice, dont over tighten blocks! lol..
lol yea im dieing already, everything should come thursday i have most stuff coming priority mail since ground takes 5 days =| so if everything goes well everything should come thursday i should have time to see where im mounting everything might mod my case etc then leak test and rock my q6600 @ 4ghzi know for me, (as you know rumy, that i just finished building my system) that the week of waiting for parts is the toughest!
